Issue with double backslash using read text file activity
Hello everyone,
I have an excel config file. One of the values is a document path (C:\project\TEMP\Entrada.txt), i need to provide this path to a Read text file activity, but when i debug the project the output path is:
C:\project\ \TEMP\ \Entrada.txt
So it doesn’t read the file.
How can i fix this issue? i already tried an assign activity doing a String.Replace but it’s not working.
Hello @snapval
If you provide the path as “C:\project\TEMP\Entrada.txt”, is it throwing any error in Read Text file activity?
Thanks
Yes,
Output: Read Text File: One or more errors occurred.
can you share the screenshot of the workflow?
Thanks
Hi @snapval,
What about this
Input
Output
Code
Path.GetFullPath(out_Config("New2").ToString)
Thanks,
Rajkumar
if you are storing the path in any variable, then replace- Var.Replace(“\”,"").tostring.
Can you check content of $exceptionDetails in Locals panel as the following?
It contains cause of error and we can solve the issue from this.
And as double backslash in local panel is C# style backslash literal in string, it’s probably no problem.
