Hi
I am a newbie to RPA and UI path. I would like to know what mini projects I can do to learn the UI path and automation.
Thanks
Hi
Thanks
@somitra_gupta
I will give a small project idea as follows:
Hi Somitra,
I would suggest you to go for UiPAth Foundation certification course which is available at free of cost. Foundation course gives some small projects and solution as well. It will enable you for UiPath and certification too.
Regards
Pawan
Refer this @somitra_gupta
Then you can proceed with some scenario’s
Thanks
