I need to extract data from a Word table, but when writing the expression in matches I don’t get data because when I get to an enter key the search is canceled.
Good afternoon @Sebastian523, Regex101.com is my favorite site for testing Regular Expressions. Definitely worth giving it a shot.
If you’re able to copy/paste the text into a comment, we can help develop the expression as well.
you need to first get the text from your word file, into uipath so you will know in which format it will be, only after you start experimenting with the expressions…
Hola Sebastian,
El generador de expresiones regulares (Regex builder) que estás usando es una buena opción. Te recomiendo realizar los siguientes pasos para obtener la información que deseas:
Nos informas si requieres mayor información!
Saludos,
Andres
Thanks @AndresTarazona the information was very useful
