I am using the event trigger http webhook, i POST this to the URL
How can i see the RAW body information in orchestrator and use the RAW info in my automations?
Hi @lr101
You can access the RAW webhook body using:
trigger payload
Add a Log Message activity to print it in Orchestrator logs.
If needed, deserialize the payload:
JsonConvert.DeserializeObject(triggerData.Payload.ToString)
Then access values like
jsonObj(“email”).ToString
If solution work for you please mark as solution
Thanks
Hi @nishi_jain
Thanks for the reply,
but i cannot see triggerData in UiPath, do i need an extra package?
do you have a connected trigger or disconnected?
if connected then the output of webhook trigger can be used to get the text content and it would contain the raw body
if disconnected we can use get event details Activities - Get Trigger Event Output
check here for full setup
cheers
We do not use Integration services, we need to do it in a way that doesnt use connectors. is there a way?
Hi @lr101 ,
If the issue is still not resolved, you can continue like this:
You need to create a variable manually first.
triggerDataObjectThen select the HTTP Webhook Trigger activity and check the Properties panel.
Look for properties like:
Map that value to the triggerData variable.
After that, you can use:
“triggerData.ToString”
If the payload is in JSON format, deserialize it using:
“JsonConvert.DeserializeObject(triggerData.ToString)”
Then access fields like:
“jsonObj(“email”).ToString”
Also make sure UiPath webhook package is installed
Thanks.
Then what webhook are you tryign to create?
as of now the only way to send data via webhook is webhook activity
if you want to trigger a process then no webhook is needed instead you can use orch api calls to trigger and also send data as part of input arguments
cheers
Hi @lr101,
If your requirement is only to trigger the automation, you can use an API Trigger.
If I understand correctly, you want to trigger a process using an API and also pass some data that will be used by the bot.
In that case, you need to create an automation in Studio Desktop with the below activity.
Thanks
