Hi Team,
string:abcde1234fghij6789klmnop456666
I want to extract or split a above string by usin regular expression in my code.Can you please help me how to do that?
Thanks in advance
Hi Team,
Thanks in advance
hey please refer this links:
Hi @cheersrpa,
When you’re asking any question, it is required that you give us all the necessary information. You told us you needed to split this string, but you never told us HOW you want it to be split or WHAT you want it to be split into. What’s your required OUTPUT? All these questions are necessary to be answered first before anyone can give a good resolution to your problem.
Also, please go though this: How to ask a good question? - #36 by ovi
Generic steps to follow whenever you want to use regex with UiPath:
Step 1: Write regex for the pattern of string you want to extract (in this case, those are only numbers). The Regex expression to use: “\d+”
Step 2: Just pass THIS Regex and your INPUT to a “matches” activity in UiPath. The output you receive will be an iEnumerable list of matched numbers (say iMatches)
Step 3: Use an If condition to check if iMatches.count>0.
Step 4: In the then part of if, use a for each statement and loop through all the matches.
Step 5: when using the matched values, do remember to convert them to string (console.writeLine(match.toString))
