i got this data by data scraping i need to shift 1 colum to right side
output needed
Hey @preethi
it returns Datatable as a result.
Use this DataColumn.SetOrdinal Method (Int32)
Example: - dataTable.Columns[“Colname”].SetOrdinal(1)
Regards…!!
Aksh
@preethi in above you have to pass at what order you want your column so for example you want your column to be at 9th position then pass it 9 to setordinal.
Here if you wants your blank column to appear at last then just get the YourDatatable.Columns.Count and use that index.
For your reference check this workflow dataScrapping (1).xaml (8.5 KB)
Regards…!!
Aksh
can you give more info? you want it after description?or at then end?
ok got it you wants to shift all columns data by one cell?
no i want 1st cell to shift right
but what about the column 3 also coming you have to skip that and write to the next columns? Have to check then… logout time will see or may be @andrzej.kniola will help till then
ok i will delete column 3
one way you can rename column names also like this
dataTable.Columns[“Col0”].ColumnName = “Name”; Similarly more I guess
or delete col3 and create a new datatable with your own header then import just datarows from first datatable to new datatable.
