How to send a Body type “Form Data” text fields using POST in a HTTP Request
Hi @All
I need to send form-data as key-value text fields(Not files) to call a post method. I am aware of the content-type(multipart/form-data) to be given inside header. But i am confused how to send the fields inside body of http post request.
for e.g: (Key-“project” & value-“victory capital”)
Please help me out.
Thanks.
Hello!
Have you tried passing these key/value pairs using the Parameters property (as mentioned in How to send a Body type "Form Data" using POST in a HTTP Request - #5 by Mateus_Cruz)?
httpRequest
I tried to add each body element like a parameter, but the post doesn’t work
Hello Julio,
In this video, I use multipart/form-data:
0:20 cURL example
1:35 Send the command from POSTMAN
2:50 Implement the code in C#
4:20 Run the code
4:50 Visual Basic code VB.NET
6:20 New Process on UiPath Studio with Invoke Code
7:20 Imports Libraries in UiPath Studio
8:30 Run the Robot to Upload and Download the file
Blockquote
Dim client As HttpClient = New HttpClient()
client.BaseAddress = New Uri(“YOUR URL”)
client.DefaultRequestHeaders.Accept.Clear()
client.DefaultRequestHeaders.Accept.Add(New MediaTypeWithQualityHeaderValue(“application/vnd.openxmlformats-officedocument.wordprocessingml.document”))
// for BASIC AUTH
Dim byteArray As Byte() = Encoding.ASCII.GetBytes(“username:password”)
client.DefaultRequestHeaders.Authorization = New AuthenticationHeaderValue(“Basic”, Convert.ToBase64String(byteArray))Dim byteArray As Byte() = Encoding.ASCII.GetBytes(“username:password”)
// for OAUTH2
client.DefaultRequestHeaders.Add(“authorization”, “Bearer YOUR TOKEN”)
Dim request As MultipartFormDataContent = New MultipartFormDataContent()
request.Add(New StringContent(“tags”), “Bad”)
request.Add(New StringContent(“displayreferencetext”), “true”)
request.Add(New StringContent(“similaritythreshold”), “0.63”)
request.Add(New StreamContent(File.OpenRead(“C:\8A.docx”)), “file”, (New FileInfo(“C:\8A.docx”).Name))
Dim response As HttpResponseMessage = client.PostAsync(“”, request).Result
Dim strm As Stream = response.Content.ReadAsStreamAsync.Result
Dim doc As Byte()
Dim ms As MemoryStream = New MemoryStream()
strm.CopyTo(ms)
doc = ms.ToArray()
File.WriteAllBytes(“C:\rpa\FORDOWNLOAD\rez.docx”, doc)
Thanks,
Cristian Negulescu
