I need to read a file inside RDP from the code in Local machine, when i’m trying that with normal activities it throws the invalid path error as it consider local machine path, Kindly help
Ideally you would be able to read the files in the shared folder between then local and rdp machine…better first move r place the file in shared folder only
cheers
