i want to Read Columns in Excel and Read Date Only Please help
-no empty values
-Select Date only
This my Flow and Excelfile
-no empty values
-Select Date only
Hi @punnipah
Inside the For each activity.
Use if activity
Not String.IsNullOrEmpty(currentitem)
Then - use log message activity it will print the date
Regards
Gokul
Inside the loop use if condition and in the condition give currentrow(0).tostring.length>0
if length >0 then do your needful process
Regards
Sreejith S S
Hi @punnipah
Try with is expression in the if activity
System.Text.RegularExpressions.Regex.IsMatch(currentitem,"\b\d{2}\W\d{2}\W\d{4}\b")
Regards
Gokul
Thank you very much ^^
