Hi Friends ,
Anyone here knows how to fixed this kind of issue .
When i tried to run it on Powershell it works ! But when i run it using the Invoke Power Shell Activites it failed.
cheers ![]()
Happy learning ![]()
Hi Friends ,
cheers ![]()
It is clear that the command is not correct @pattyricarte
I see you are not passing the exact command which you used in the power shell manually in UiPath activity
Ok @HareeshMR can you tell me what is the exact command i am a newbie using this activity !!! Many Thanks.
Please try passing the same command you have in the invoke powershell activity through uipath activity and check the response once @pattyricarte
Ok @HareeshMR i will try to elaborate and set me to the right directions…
Where should i passed this command .Do i need to set it in the properties of Invoke Power Shell Activity .
And How should i get the response.
Thanks in advance for your reply…
yeah, you are doing it right @pattyricarte ![]()
But as it is a parameter, you need to send it without double quotes, but it will send the path to the power shell.
Do these steps:
Hi @HareeshMR
I already did that but i dont have any luck.
