Hi, I am trying to get data that extract from web and place them into each column that I prepare. (“30122564”, 17012565", “01022565”)
However, every time I extract the data it end up adding new column. (“(Day)(0).ToString”) Also it only get the last result from the list that.
Here is example
I want the data in column “(Day)(0).ToString” (10 rows) to be in column “30122564” and after that repeat for the next column “17012565” (another 10 rows).
Objective
- To put all data that extract from web in the column of the date that has been add before hand.
- repeat the process by place next data in the next column.
Thank you in advance.
