Help with if/then/else Logic using LINQ
I am trying to utilize LINQ to speed up the processing of a table that I have. I can get the expression to pull just one scenario, but not all that are required.
I have a table similar to the one above, but I’ve simplified it for this question. Date1 correlates with Thing1, Date2 correlates with Thing2, and Date3 correlates withThing3.
For each Employee I need to make sure that if Thing1 is true, then Date1 has a date. If Thing1 is false, then Date1 should not have a date.
Same applies for Date2/Thing2 and Date3/Thing3
Each date/thing discrepancy that doesn’t meet the above criteria would be exported to a new data table.
Thanks in advance and let me know if clarification is needed.
HI,
What is your expected result? Is it filtered datatable? If so, the following will work
dict =New Dictionary(Of String,String)From{{"Date1","Thing1"},{"Date2","Thing2"},{"Date3","Thing3"}}
Then
arrDr = dt.AsEnumerable.Where(Function(r) dict.Any(Function(kv) not DateTime.TryParse(r(kv.Key).ToString,New DateTime)=CBool(r(kv.Value)))).ToArray()
Sample20230324-1L.zip (8.8 KB)
Hi @mbuehler
Give a try to this.
dt_input.AsEnumerable.Where(Function(x) Not( ((x("Thing1").ToString.Equals("TRUE") And Not String.IsNullOrEmpty(x("Date1").ToString)) Or (x("Thing1").ToString.Equals("FALSE") And  String.IsNullOrEmpty(x("Date1").ToString))) And ((x("Thing2").ToString.Equals("TRUE") And Not String.IsNullOrEmpty(x("Date2").ToString)) Or (x("Thing2").ToString.Equals("FALSE") And  String.IsNullOrEmpty(x("Date2").ToString))) And ((x("Thing3").ToString.Equals("TRUE") And Not String.IsNullOrEmpty(x("Date3").ToString)) Or (x("Thing3").ToString.Equals("FALSE") And  String.IsNullOrEmpty(x("Date3").ToString)))) ).CopyToDataTable
Sample Workflow:
Sequence6.xaml (9.1 KB)
Hope this might help you.
(From d in YourDataTableVar.AsEnumerable
Let cs1 = new String(){"Date1","Date2","Date3"}
Let cs2 = new String(){"Thing1","Thing2","Thing3"}
Let dpc = cs1.Select(Function (x) DateTime.TryParse(d(x).toString.Trim, nothing)).toArray
Let tbc = cs2.Select(Function (y) CBool(d(y).toString.Trim)).toArray
Let chk = dpc.SequenceEqual(tbc)
Where chk
Select r = d).CopyToDataTable
  • cs1, cs2 could be externalized so it will not be done for each loop
  • the dpc, tbc constructions can be modified if needed e.g DateTimeParseExact…
Handling empty results we can do as described here:
:ambulance: :sos: [FirstAid] Handling of The source contains no DataRows exception - News / Tutorials - UiPath Community Forum
Thank you all for your possible solutions, however I will no longer require a solution to this as the scope of the project changed, directly impacting the need for this.
