Help with for each datarow loop
hi all,
i have a problem with a test i am trying to run. i am running a for each data row loop inside another each data row loop.
what i have is a tale called dt_source and then i need to extract the unique values for the column CP_SERVICE - consider it a reporting group.
then i need to loop through the source table with each unique CP_SERVICE that will group the survives (eg all rows where the service of cp1, cp2, cpe3 etc) together and create a text file that i will use for an email.
i can see that all the unique cp services are being created
Also i can see that it processed the details for cp1 correctly - (i know in the example that i have here that it repeats the process afew times but i am ok with that for now)
but it does not process anything for cp2 or cp3, or write anything for them to the text file
if i change cp1 to cp4 the the files for cp2 will be processed instead
any help to get the file working for cp2 and cp3 would be greatly appreciated
workflow is attached and source file is attached
thanks,
Source.xlsx (12.0 KB)
Main.xaml (19.8 KB)
some parts could be avoided (e.g. heavy dt text outputting, as we can do inspections with the debugging panels)
We would recommend to use for the filter output a seperate variable: dtFiltered
As a group by is implemented also have a look here:
Maybe you want to shift to a groupby LINQ
in the actual workflow i dont have the outputs or write text files. it is there in this example just to show that the dat should be there, just is not being picked up correctly
i will have a look at the grouped by linq and see how i get on with it
thanks
so i had a look at the group by with linq and i just cannot get it work work. i tided up my workflow a bit and got rid of the repeating rows but it still will not bring in any unique cp after the first one processed
i feel that something very minor is wrong, just can not find it
Main.xaml (20.0 KB)
when referring to your input what is the expected output?
the inputs are cp2, cp3 and cp4
output should be - what you see in the second loop for cp2, being repeated for cp3 and cp4
for cp3 and cp4 i can see that they are being registered an input - but not being fed into the second loop
we avoid misinterpretations when you share the output samples. Thanks
no problem at all - this is the correct output for cp2
just trying to get the same result for cp3 and cp4 currently neither are making it correctly into the second loop
@adrian_sullivan
Rather than log message showing thw input file and the output file or the process flow would help
the process is attached form 30 mins ago along with the source file
@adrian_sullivan
If you need all cp_service one oafter the other…then first use sort datatable with cp_service as column and then loop theough
Yes this is correct
But we also got told:
So we assume that there is a risk of used / development and this sample XAML can be inconsistent / different
As we told:
But cannot see any adaptions on the second XAML we dont know what was done in real
With a feedback of:
we also dont know what was done at this part in detauls and still cannot derrive any details on result and difference on the expected output
Additional: we do see a few hints on the creation of HTML code in a way which also can be done different and more clean/straightforward.
So all in all, there is a risk on misinterpretations on what is needed
We also agree to
as a few hints are given and maybe the from your end DefaultView & Filter DataTable (a typical GroupBy style) maybe is not needed.
So to close and giving some hints on the possible next actions
  • check what was aimed: data grouping or filtering
  • check on e.g. Activities like Create HTML Content / Custom Packages which can simplify the dataTable to HTML Table tr/td generation part.
so finally figured it out
the problem was with my filter in the first loop
i was setting it lo look at only cp2 - which it was doing
then in loop 2 i was looking in dt_source - with the filter of cp2
when loop 2 ran for cp3 or cp4 it could not find anything as it was already filtered for cp2
so i had to go back to the first filter and created a temp dt - dt_sourcex
that when when entered loop 2 it could filter correctly and find cp3 and cp4 (as the full dataset was there)
to give me the expected output of
i knew it was something small - just took me more time than i care to admit to find what it was…
thanks for the help and pointing me in the right direction
