Extract Required String from Email Body
Team,
I need to extract Requestor Email id ie daniel.arcaro@fiserv.com from below email body, any suggestions :
Click here to view Task: TASK3089025
The Requested Item is RITM2544177 and the Task is Assigned to group: Card-TechOps-Debit BOS-T1
The following information below is from the Task and Requested Item:
Task Information:
Short description: Debit BOS: BATCH FILE ATTACHED FOR AUTO ADJUST
Description: SQL>
COUNT
545
SQL> SQL>
DB SUM(AMOUNT)
D 122894.71
C 78671.74
Requester Information:
Email: daniel.arcaro@fiserv.com
Phone: +1 (856) 8436235
Requested Item Information:
Requester Details:
Requested for: Daniel Arcaro
Opened by: Daniel Arcaro
Primary contact: Opened by
Request Details:
Which support team is this for?: Debit
Which group are you requesting?: Debit BOS
What client(s) is this for?: Debit Card Network
What platform is this for?: EPOC
What sub-platform?: PROD
What is the priority?: Medium
Type of Debit request.: Question
Short Description: BATCH FILE ATTACHED FOR AUTO ADJUST
Detailed Description: SQL>
COUNT
41
SQL> SQL>
DB SUM(AMOUNT)
D 682653.71
C 9545.22
SLA duration remaining: 2 Days 23 Hours 59 Minutes
Ref:MSG399659801
How about the following pattern?
(?<=Email:\s+).*
 System.Text.RegularExpressions.Regex.Match(yourString,"?<=Email:\s+).*").Value
Hi @prerna.gupta
How about the following?
System.Text.RegularExpressions.Regex.Match(YourInputString.Trim,"(?<=Email:\s+)\S.*").ToString
Regards
Gokul
Using your Solution i’m getting Output as below where @ is extra:
@"daniel.arcarofiserv.commailto:daniel.arcarofiserv.com
Using this solution i’m getting Error
Assign: parsing “?<=Email:\s+).*” - Quantifier {x,y} following nothing.
Sorry, it’s my typo. Expression should be the following.
System.Text.RegularExpressions.Regex.Match(yourString,"(?<=Email:\s+).*").Value
If you have an @ in the input? @prerna.gupta
I don’t think so it will come while using the expression?
Can you share the screenshot?
Regards
Gokul
With you r solution as well @ is coming extra
As this @ sign is outside of string literal, we can ignore it. (it’s one of C# style string expressions)
Please see the following document section2 in details.
BTW, if you need mail address without mailto: section, the following will work.
 System.Text.RegularExpressions.Regex.Match(yourString,"(?<=Email:\s+)[^<\s]+").Value
