I use the below code for extracting matching rows on the given condition; but getting the error of “converting Double to string not allowed.” Please help.
dtMaster.AsEnumerable().Where(function(row) dtCancelled.AsEnumerable().Select(function(r) r.Field(Of String)(“Column2”.ToString)).Any(function(x) x = row.Field(Of String)(“Column1”.ToString))).ToArray
@glory1
IT Looks Like you want to do join between master and cancelled
So yo can do it with the query syntax (within an assign activity)
(From d1 In dtMaster.AsEnumerable()
Join d2 In dtCancelled.AsEnumerable()
On d1(“Column1”).toString Equals d2(“Column2”).toString
Select d2).toArray
In your Statement constructs like r.Field(Of String)(“Column2”.ToString) are better to avoid. Forcing to String maybe cause this issue give try on r(“Column2”).ToString
But if I am right with the assumption of Data Join also have a look on the Join Datatable Activity
