Hi all,
I have created a custom activity. The purpose of this activity is to encrypt password and convert it ToBase64string. I have tested code and it’s working fine in Visual studio. I have created a nuget Package from this and using into Uipath.
But when i tried my activity in uipath it’s not working.Showing error-
“RemoteException wrapping System.FormatException: Invalid length for a Base-64 char array or string.
at System.Convert.FromBase64_Decode(Char* startInputPtr,…”
My code is -
public string EncryptStringAES(string plainText, string sharedSecret)
if (string.IsNullOrEmpty(plainText))
throw new ArgumentNullException(“plainText”);
if (string.IsNullOrEmpty(sharedSecret))
throw new ArgumentNullException(“sharedSecret”);
byte[] outStr; // Encrypted string to return
string str_outStr;
RijndaelManaged aesAlg = null; // RijndaelManaged object used to encrypt the data.
try
// generate the key from the shared secret and the salt
var key = new Rfc2898DeriveBytes(sharedSecret, _salt);
// Create a RijndaelManaged object
aesAlg = new RijndaelManaged();
aesAlg.Key = key.GetBytes(aesAlg.KeySize / 8);
// Create a decryptor to perform the stream transform.
var encryptor = aesAlg.CreateEncryptor(aesAlg.Key, aesAlg.IV);
// Create the streams used for encryption.
using (var msEncrypt = new System.IO.MemoryStream())
// prepend the IV
msEncrypt.Write(BitConverter.GetBytes(aesAlg.IV.Length), 0, sizeof(int));
msEncrypt.Write(aesAlg.IV, 0, aesAlg.IV.Length);
using (var csEncrypt = new CryptoStream(msEncrypt, encryptor, CryptoStreamMode.Write))
using (var swEncrypt = new StreamWriter(csEncrypt))
//Write all data to the stream.
swEncrypt.Write(plainText);
outStr = msEncrypt.ToArray();
str_outStr = Convert.ToBase64String(msEncrypt.ToArray());
finally
// Clear the RijndaelManaged object.
aesAlg?.Clear();
// Return the encrypted bytes from the memory stream.
return str_outStr;
Can any one suggest me how to resolve this ?
