Data Group and Filter Problem
Here is my excel file.
sample.xlsx (21.4 KB)
Here are the colors of automobiles :point_down:
How to grouping the cars on the “Otomobil” page according to their Color values and drawing the value of how many they are in a “Color Quantity Page” ???
Note : Needs to do it with linq methods
Can you also share expected output?
Same colors will be following each other.
How about the following sample?
Sample20230718-1aL.zip (21.0 KB)
It seems fine but mentor wants me to do it with linq methods
Can you try the following expression?
dt = dt.AsEnumerable.OrderBy(Function(r) r("Renk").ToString).CopyToDataTable
I ll let you know when i am able to try it
please find the attched result file.
sample.xlsx (20.9 KB)
for linq you can use following query,
Dt2=Dt.AsEnumerable().OrderBy(Function (row) row(“Renk”).ToString).Select(Function (row) row).ToArray.CopyToDatatable()
Yes it works but i also want to count how many different colours and total numbers of colours like in the following.
How about the following sample? This outputs count sheet in Sheet2.
dtCount =dt.AsEnumerable.GroupBy(Function(r) r("Renk").ToString).Select(Function(g) dtCount.LoadDataRow({g.Key,g.Count},False)).CopyToDataTable()
Sample20230718-1aLv2.zip (22.5 KB)
Also it has to be string, right ?
Does the above sample work? Did you modify the workflow?
For now, can you check dtResultsPage and/or dtRenkAdet is null or not at Locals panel when error occurs?
My bad!
Output of Build Data Table was empty :robot:
Thanks for the solution :+1:
