“Type Into ‘INPUT’: Column ‘first number’ does not belong to table DataTable.”
every time I run my robot the robot stops and sends me this error and I don’t understand what does it mean, please tell me what should I do in this case
@Omar1 Please change the Title to a suitable one , so you can get proper help on it
Regarding your question it seems that the first number which you used in Type into does not belong to data table
please check if your datatable contains that column name
If possible can you add the screenshot
regards
Shanmukh
Hey, @Omar1
try doing this row(0).ToString instead of giving column name
you can cross check if you are passing the right Column name or not
cheers
Hi @Omar1,
Can you please provide some screenshots to explain your topic and make it more clear?
Thanks & Regards,
Apurba
Can you Print the CustomerData datatable and show us
To print you can use Output datatable give input as Customerdata and output for that as Text and then use message box ,in box give text
just click on it and it will open
Columns “first number” and “last number” don’t exist. Did you mean “first name” and “last name”?
OMG!!! i didn’t recognize it
thank you very much
