Hello,
I have an input datatable and produce an output datatable using LINQ.
Anyone, please help.
Nidhees
Hello,
Nidhees
Hello @Palaniyappan,
“TransactionNo” column has duplicate value and accordingly, i have to SUM the “Debits” column value for each duplicate transaction no.
Nidhees
Yay sorry… I didn’t see that clearly,
Let me check once buddy
Cheers @nidheessingh
Hope would help you @nidheessingh
Outdatatable = (from table in dt.AsEnumerable()
group table by table.Field(“TransactionNo”)
into groupedTable
select new
{TransactionNo = groupedTable.Key,
Debits = groupedTable.Sum(x => x.Field(“Debits”))}).ToArray.CopyToDatatable()
Where Outdatatable is a variable of type datatable
Kindly try this and let know whether this works or not buddy
Try this as well
ExcelData.AsEnumerable.Sum(Function(x) Convert.ToDouble(x(“Debits”).ToString.Trim) ).ToString
Thanks
Ashwin S
Aah sorry one second
Yes remove one of the curve bracket here lik this
…x.Field(“Debits”)})
May i what was the error that occurred @nidheessingh
In your previous image, you have “=>” when declaring ‘x’, which is a C# syntax. You need to use .net syntax which would be .Sum(Function(x)
However, I think you have other issues with your LINQ code.
You can check out this post here about using GroupBy for Sum:
Regards.
Hello @balupad14,
I have used the Aggregate function “SUM” on a “Debits” column along with “Group by” on “TransactionNo” but while execution, I am getting error on row no-101755.
I checked the data on these specific cells(i.e. “Debits” and “TransactionNo” columns) and everything is OK.
Input Sheet:
Could you please help me where is the issue?
Nidhees
Hi ,
Can you attach the file to test at my side.
Regards
Balamurugan.S
Hello @balupad14,
Please find the updated sheet with few data.
In this sheet, I am getting an error at row# 18.
Nidhees
Hi @nidheessingh,
I will let you . after it verified.
Thank you
Balamurugan.S
Hi @nidheessingh ,
The problem is here
The cells should not be blank. It must have the value. I have set it as zero.
It will give result like below
Sample : nidheessingh.zip (9.5 KB)
Regards
Balamurugan.S
