Hi, still here. Now when running a While problem to find prime numbers, the program tells me that 0 and 1 are prime numbers. Otherwise, the results are right. What am I missing?
- Create a Counter variable(int32)… Counter=2
- create a variable(int32) (NumberToCheck)
- IsPrime (Boolean)
For example
NumberToCheck=13
While
While (counter <= Math.Sqrt(numberToCheck))
If (numberToCheck Mod counter = 0)
Assign: isPrime = False
Break
Else
Assign: counter = counter + 1
If (isPrime)
// It’s a prime number
Log Message: “The number " & numberToCheck & " is prime.”
Else
// It’s not a prime number
Log Message: “The number " & numberToCheck & " is not prime.”
Hope this Helps
Take i=1 Then Take the input from the use save it in number variable
Checks if the number is divisible by
i . If yes, increments the counter cAfter the loop, checks if
c is equal to 2, and logs the result prime or not primePrimeOrNot.zip (2.7 KB)
Hope this Helps ![]()
Use a if condition and ignore checking when the value is 0 or 1 as mod of 0 or 1 with any number will be 0
Thanks Anil, problem solved.
