Fine
Try like this (it might have a space in it)
Convert.ToDouble(retValue.Replace(“-”,“”).ToString.Trim.Replace(" “,”").ToString)
Cheers @AryanSingh
Fine
Cheers @AryanSingh
will it give an error if there value is negative but does not has space in between like 0.01 or 0.02??
it looks like we have this kind of value
is that condition used buddy
Cheers @AryanSingh
I hope this should work
If possible can you share the workflow altogether in a zipped folder
Cheers @AryanSingh
