Write range problem
May I ask what mistake do i make then the current result like that?:
It is supposed the result should be like this,
Can anyone help me to check my workflow and enable me to cope with this issue? Many thanks!!!
My workflow:
MU-Rep sorting ver…xaml (30.3 KB)
Hey @Happydayyy Instead of sending an individual xaml, can you send a zip file? I can’t open the xaml on my machine!
asking (file://LAPTOP-PTETHOIB/Users/user/OneDrive/文件/RPA%20placement/asking)
How about this?
Or you can follow How to copw with issue “cannot set unknown member”
I also sometime may encounter this problem as well. Sometimes I open the workflow inside the studio is okay, but sometime okay sometime not okay…
