GoogleSpreadsheet “Write Range” activity throw an error I mentioned below. Any help?
An error has occured
Source: Newtonsoft.Json
Message: ISerializable type ‘Google.GoogleApiException’ does not have a valid constructor. To correctly implement ISerializable a constructor that takes SerializationInfo and StreamingContext parameters should be present. Path ‘Error’, line 1, position 1275.
Exception Type: JsonSerializationException
Newtonsoft.Json.JsonSerializationException: ISerializable type ‘Google.GoogleApiException’ does not have a valid constructor. To correctly implement ISerializable a constructor that takes SerializationInfo and StreamingContext parameters should be present. Path ‘Error’, line 1, position 1275.
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateISerializable(JsonReader reader, JsonISerializableContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at UiPath.Shared.JsonParser.DeserializeObject[T](String jsonValue)
at UiPath.Models.UiPathDuplexProxy.<>c__DisplayClass18_0.b__0()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
