I have a robot that uses Write Range activity, and it was working without errors even though an excel file has hidden columns. However, after I updated packages of the robot, the Write Range raises an error: Write Range: Cannot write to the target range because it has hidden rows. Remove any filters or unhide rows and try again.
I believe this is a known bug with the Excel activity and I can replicate this behaviour even in the latest preview. However it doesn’t seem to occur with the Workbook > Write Range activity.
Are you able to try the workbook write range activity instead?
There is the following note in it. So you might be able to handle it version 2.8.4 or below.
Note:
In UiPath.Excel.Activities v2.8.5 and later releases an error is thrown if you use this activity to write to a range that contains hidden rows or columns.
Thank you so much for your answer. I eventually used macro to hide/ unhide columns so the entire process looks ugly. I think I should have use Workbook write range.
If downgrade, there might be maintainability matter in long term usage. For example, even if bug is found, there is no way to fix it. So it might be better to use ReadRange and vba code for unhide/hide columns.
