YT channel opertions2.zip (17.3 KB)
i am unable to remove subscribers word from the column
You can use the Find\Replace activity to replace the Subscribers with empty.
If the above is not perfect solution, elaborate your query for better understanding.
Hope it helps!!
Try the below way
Excel.Sheet("Sheet2").Range("C2:C"+Excel.Sheet("Sheet2").DataTableValue.RowCount.ToString)
Input:
Output:
sports club responses.xlsx (16.9 KB)
Cheers!!
dt.AsEnumerable()
.Where(row => row.Field(“subscribers”).Contains(“subscribers”))
.ToList()
.ForEach(row => row.SetField(“subscribers”, row.Field(“subscribers”).Replace(“subscribers”, “”)));
Hope it works
Hi @Adithyeshwar_goud ,
Find updated code hope it works for you ![]()
YT channel opertions.zip (17.5 KB)
Vinit Mhatre
You need to replace the subscribers first and then try to convert the value to double.
→ Use the for each row in data table and give the below assign activities within the for each as shown in below imgae.
use the below in assign activities.
CurrentRow("subscribers") = CurrentRow("subscribers").ToString.ToUpper.Replace("SUBSCRIBERS","").ToString.Trim()
CurrentRow("subscribers") = If(CurrentRow("subscribers") IsNot DBNull.Value, Convert.ToDouble(CurrentRow("subscribers")), 0.0).ToString.Trim()
Main.xaml (13.4 KB)
Regards
