When running in Debugging Not able to see the Output window on Right Side and Left side real time value taking
Can anyone help when I run the process in debugging mode the Left side Real Data Visible and Right side Output Result window not visible. It’s look same as we run in normal mode by pressing the F5. In the older version 19.2.0 both the window was visible but as I have updated into the 19.3.0 the Output window are not visible while debugging. we have to check the result in the below left output icon. Same as we see while running in normal mode.
Notice the locals tab in your screenshot ? next to Activities / snippets ? , that tab would show you run time variable values … try clicking on it and check if its visible ?
Also try resetting your settings ,
By default you should see locals tab activated and prominently displayed once you click debug
