When only data availabe in excel (with reference to serial number), it should go and click add item icon in web and do entry
when only data available in excel data field(reference with serial number), it should go and click add item icon in web and do entry.
I know how to do data entry in web, but don’t know, how to give condition
Pls help
@nanrajj Attached zip file meets your requriement please check it
WebEntry.zip (13.9 KB)
thanks for your reply.
Hi, in the excel, I want to read data till it reaches “Grand Total”. so I gave condition, row(0).ToString.Contains(“Grand Total”) in if condition, if yes, it will break, otherwise, It will continue other function.
But my query is, I want to get the count of rows, which is only filled before “Grand total”. and then iterate through the count to perform other function.
Can it come under if condition
Pls help
