Hello,
The ML Extractor activity states that it uses a “server side OCR Engine”, can we know what is this engine? Does it use 3rd party ocr engines or what?
Thanks
It depends on the instance. yes, in some cases, we are using 3rd party OCR engines.
We recommend that the server side OCR is not checked if you are using a good OCR engine in your Digitize Document activity - this is to ensure a better response time as OCR is a time consuming activity that increases the response time.
Thanks for your response. Can we know what is the 3rd party OCR?
