Hi Everyone,
i have one query about single excel process scope activity and when to use this activity in UiPath.
Thanks and regards,
Adarsh.
Hi Everyone,
Thanks and regards,
Adarsh.
When you want to work with multiple excel files to not duplicate excel processes all use excel files can be kept under the same excel process scope
On the other hand if we know only one excel is being used then single excel scope can be used for the excel process and to control the settings
Opens or reuses an Excel process, loads the Excel project settings and applies them to the associated Excel file. This activity supports working with a single Excel process. If you need to work with multiple Excel processes use the Excel Process Scope activity.
For more details please refer the below documentation:
Excel Process Scope
Single Excel Process Scope
Regards
can i use Two use excel file activities in single excel process scop as shown below?
Most of the activities won’t work when you are using multiple excel’s in a single excel process scope activity. If you want to use multiple excel’s then you must use excel process scope activity.
Regards.
