Hi All,
what is difference between Click and Click Text
UI Automation - Element - Mouse - Click
Text - Mouse - Click Text
how do identified a element which is click or Click Text… Can please provide a real time example
Thanks
Sreeni
Hi All,
Thanks
Sreeni
Hello,
See below the difference:
Click - It’s used to click by page element.
Click Text- It’s used exactly by text.
Is Click Text is using some method like scraping or OCR?
Wondering which one is faster between Click or Click Text?
It depends on the situation you’re working on, but both options are fast. Unlike the click on text you can use the click directly at the position of the text, and click you to use by the element.
