Way to count up starting from timing of go to running state
The amount of time specified in the Stop After section elapses according to the specifications, even if the job is queued. For example, if you schedule a job to run at 1 p.m. and set it to stop after 20 minutes, the job stops at 1:20 p.m. even if it had stayed in a queue until 1:15 p.m., and then started.
at https://docs.uipath.com/orchestrator/docs/managing-schedules
I want the Stop After count start time to be the time when the job goes from the queue state to the execute state. Don’t you know a good way?
