Want to add Dispatcher in UiPath only using reFramework for a simple read range and add to queue item activity. where should i put the sequence ?? when i try to run/debug it goes into a loop of system Exception , i deleted Get transaction state and also nothing is there in Init File
Hi @samantha_shah
Please try to test the following project.
Academy-REFTabular-UiDemo.zip (6.6 MB)
Cheers!
You shouldn’t use REFramework for something so simple.
sure let me try it and then will let you know
You can refer to ReFramework guide which comes with every project you create with the ReFramework template.
Cheers!
Thanks,
Ashok ![]()
