I tested the Create Task Form activity and the Wait for Form Task and Resume activity to test the Community Action Center. The Create Task Form activity worked fine, but the Wait for Form Task and Resume activity did not.
After creating a task using Create Task Form and moving on to the Wait for Form Task activity, does not the waiting have to end when all assigned tasks are processed? Or am I misunderstood?
In the lecture video I watched, I knew that waiting would end when all assigned tasks were processed.
However, the difference between the lecture video and the practice environment is that in the lecture video, lectures were given by an actual orchestrator, and I tested with a community orchestrator.
Thanks for reading the long introduction and I hope it answers my question.
Q1. Is it correct that Wait for Form Task activity automatically terminates Wait when all assigned tasks are completed?
Q2. When using the Wait for Form Task activity as a community orchestrator, is it correct to manually click the Restart button in Uipath Studio after the person in charge has completed the task?
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
