You can also use the below to extract parts of the date.
Month(Now).ToString or Year(Now).ToString
etc.
That should also return an integer. So for conditions it’s like Month(Now) < 3
If you want it zero-filled, then do Month(Now).ToString(“00”)
If you have a DateTime variable, you can set its Default to Now, then use the variable like… Month(timeToday) or Month(timeToday).ToString
That’s how I do it.
Oh, I also wanted to add that I’m pretty sure you can compare DateTimes in the condition.
So for example, you have a dateTime variable set…
Q2 = CDate(“03/01/2017”)
Then, you can use that in a condition Now < Q2
This method will incorporate the time and year with the date too so might be more sustainable.
Of course, there are probably multiple solutions for what you need.
