Using UiPath Activities to fix data synchronization failure in Agent Index
How do I check the status of the Index using UiPath activities?
Issue Description
When using the Index in agents, if the Index fails to sync, the agent encounters the Data synchronization failure errors.
Root cause
The error occurs due to an Index ingestion failure, which prevents the successful synchronization of the indexes.
Resolution
  • Check the status of the Index using the Wait for an Event activity in UiPath GenAI Activities and Resume
  • Check the operation for "Index Completed"
  • Once the synchronization is confirmed, the agents will run successfully without encountering any issues.
