I have used Data Manager to tag invoices. I have created an extraction that has created 4 files (2 folders, a split.csv file and a schema.json file). Is it possible to use the same dataset for training and evaluation when running a full pipeline run in AI Centre?
If not, what is the best way to split the data files extracted from Data Manager? Can I use the same dataset for both (See below).
Thanks,
