I wants to paste below excel data table in same format in outlook body.
By HTML,it is removing all the number formats and color coding.
Please suggest some thing.
It is not giving the same color coding and number format. I have tried this.
If you want to do this with HTML, you have to add a style sheet to the table. Also you have to convert the numbers to string to retain the format.
Can you please share the code if possible
I have used shell scripting to copy and paste excel data in outlook body.
This preserves the format as well. Steps to replicate the process is as follows:-
Step 1 - Open a notepad and paste the below code and save the file with .ps1 extension
$x1 = New-Object -comobject Excel.Application
$UserWorkBook = $x1.Workbooks.Open(" excel path")
$UserWorksheet = $UserWorkBook.Worksheets.Item(1)
$UserWorksheet.activate()
$rgeSource=$UserWorksheet.range(âA1â,âD11â)
$rgeSource.Copy() | out-null
$Outlook = New-Object -comObject Outlook.Application
$Mail = $Outlook.CreateItem(0)
$Mail.Recipients.Add(âenter sender emailâ)
$Mail.Subject=âenter subjectâ
$oDoc = $Mail.GetInspector.WordEditor
$oRange = $oDoc.Range()
$oRange.InsertParagraph
$oRange.InsertBefore(âHi Team,â)
$oRange.InsertParagraphAfter()
$oRange.InsertAfter(" enter the mail body")
$oRange.Collapse($wdCollapseStart)
$oRange.Paste()
$oRange.Collapse($wdCollapseEnd)
$oRange.move(4,3)
$oRange.InsertAfter(âThanks & Regards,â)
$Mail.Display()
$Mail.Send()
Step 2 - If you encounter the below error- âps1 cannot be loaded because running scripts is disabled on this system.â then you need to create a .bat file using notepad to execute the shell script-
@echo off
color 1F
echo.
C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -File "shell script path "
:EOF
echo Waiting seconds
timeout /t 40 /nobreak > NUL
Step 3- You can then use start process activity in UiPath to execute the bat file.
The bat file calls and run the shell script which sends email.
Let me know if this helps.
Thanks & Regards,
Lipika
Hi @Lipika_Porey,
The excel path would be dynamic. So how would i pass that dynamic path in notepad file?
This may not be an ideal solution but still can be tried-
You can use Run Powershell script activity from uipath to call the shell script like below. the activity is available under UiPath.Script.Activities
And in the shell script you can add the below code-
[System.Reflection.Assembly]::LoadWithPartialName(âMicrosoft.VisualBasicâ) | Out-Null
$name = [Microsoft.VisualBasic.Interaction]::InputBox(âEnter the File nameâ, âUser Input Dialogâ, ââ)
This basically generates an user input dialog; where we need to enter the file name without the double code. using uipath activity you can enter the file name in below iput box
I am still trying to find a way to pass the dynamic file name using argument. Till then let me know if this works.
Thanks & Regards,
Lipika Porey
