I want to take screenshot of selected range in excel and then save the screenshot in new tab of same file.
Please help!!!
Please help!!!
Hi, copy the range and use clipboard.getimage method using invoke method
Sorry for late reply. Can you share your code. It will help a lot.
@Mukul_Chandravanshi
Here is your xaml buddy
screenshot.xaml (7.1 KB)
Kindly close this topic with right comment marked solution once it is resolved buddy that could help others looking for ideas under yourtopic
hope would help you
Hi @Mukul_Chandravanshiscreenshot.xaml (8.5 KB)
please find the xaml , Pass the input excel,image aruguments and specified the range
import the image in new sheet follow the below procedure
go to Object tab in excel then import the ur image in specifed rage
check and let me know still ur are facing problem.
don’t need to go Object Tab also i have one more correct Soultion here.
check this it’s awesome
TakeRangeScreenShot.xaml (10.5 KB)
cheers…
yes its nice and optimized.
