HI All,
We have an issue where our bot goes into our house application, clicks a button to export some xml and then saves it to a local drive. The bot then needs to move the folder and contents to a completed folder.
Heres the issue. When the bot clicks the export button, IE loads a window displaying the xml, the bot does a CRL + S on the content of that window and then saves it to the local drive. The bot then tries to move the folder and its contents to a completed folder but can’t because its locked. On checking myself manually i notice the folder can’t even be deleted as it says its being used by another process. I can however delete the folders contents. Another thing i notice is the folder seems locked to IE, i say this because If i close IE then it releases the lock to the folder and i can delete or move the folder. Of course closing IE isnt an option at all to a solution as the bot needs to keep it open to process more transactions.
Any suggestion would be hugely appreciative as this is a blocker for our project.
Rohan
