Hi there!
Imagine I have the following XML file:
<?xml version="1.0" encoding="ISO-8859-1"?>
<DOSSIER TYPE="110">
<my:address><div xmlns="http://www.w3.org/1999/xhtml">
<div><font size="2" face="Arial">Testing </font></div></div></my:address>
</DOSSIER>
If I deserialize this xml and use the following writeline:
"Text: "+xmlDoc.Element(“DOSSIER”).Element(“my:address”).Value
then I will get the error:
Message: ‘my’ is an undeclared prefix. Line 3, position 2.
The problem is due to the tag “my:address”. If I remove the “:”, the error disappears. Do you know how to solve the issue with the “:”?
Thank you.
