UiRobot.exe not starting as UI or in System tray - attended robot
Hello,
with Version 2020.10. running the uirobot.exe executed a UI to run robots which had nuget packages within “program data” packages folders.
With version 2022.10 the command line just provides options and no UI by default anymore.
did the UI disappear? I can start the nugget packages by using execute --file “nuggetlocation” but this is not very user-friendly for the people working the attended Robot
In version 2021.4, old style Robot tray was deprecated. And we can use UiPath Assistant instead it. Can you try this?
