UIPath Studio size problem on low resolution monitor
I’m working on a remote desktop with a resolution of 1440x900, and Windows behaves a bit weird where it looks as if everything is a bit zoomed in, but I cannot change the sizes as it is remote (Windows doesn’t let me).
I would be okay with this, however UiPath Studio opens with half of the software off the screen, and when I maximize it, some of it is cut off to the side of the screen. (I can’t even manually resize it)
Do you have any ideas why this is happening? I am using RDCMan for remote.
Hi @Rick25
Pls check this doc,
