Uipath select query doesnot work with oracle if the column datatype is long in oracle. Kindly help how to solve. Iam able to fetch other column values
UiPath select query doesnot work with oracle if the column datatype is long in oracle. Kindly help how to solve. Iam able to fetch other column values
@Hema_Manoharan
Welcome to the community
Can you please tell what error you are getting exactly
And is that field containing a huge data?
Did you try with a single line?
Dear Team,
Yes. It stored huge xml data. Except that Column, i am getting values for other columns.
Thank u
Even when i try to fetch single record, that particular column alone s empty.
Hi All,
Kindly help on this item.
@Hema_Manoharan
Which drivers are you trying with?
Odbc?
