UiPath Agentic AI – A Visual Framework for Building Agents That Reason, Plan, and Act
Automation is rapidly evolving beyond rule-based workflows. Organizations today need systems that can understand intent, reason through uncertainty, and autonomously coordinate actions across applications, data, and human decisions.
This shift marks the rise of Agentic AI — automation powered not just by logic, but by cognition, context, and orchestration.
To help visualize how these capabilities come together inside the UiPath ecosystem, I created the Agentic AI Periodic Table:
a conceptual framework representing 66 foundational elements behind intelligent, enterprise-ready agents.
UiPath Agentic Automation Periodic Table
You can view the original LinkedIn post here:
Each “element” represents a concept, skill, pattern, or tool that contributes to building agents that behave more like digital collaborators — not scripts.
This article breaks down the core pillars behind the framework.
1. Core Concepts of UiPath Agentic AI
Agentic automation in UiPath is built upon a set of architectural foundations that enable reasoning, memory, orchestration, context-awareness, and safe operation.
Below are the primary pillars represented in the periodic table.
1.1 Maestro (Ms) — The Orchestration Layer
Maestro is the execution backbone of agentic systems.
It brings together:
  • agents
  • robots
  • humans
  • data
  • events
  • long-running workflows
All through executable BPMN models.
Core roles of Maestro:
  • Modeling end-to-end agentic processes
  • Coordinating multi-agent flows
  • Handling parallelism, conditions, and escalation
  • Integrating human-in-the-loop checkpoints
  • Providing full auditability, traceability, and monitoring
This is where autonomy becomes accountable.
1.2 Autopilot (Ap) — Natural-Language Intelligence for Builders
Autopilot accelerates every part of the automation lifecycle:
  • Generating workflows
  • Refactoring selectors
  • Writing test cases
  • Summarizing documents
  • Producing natural-language insights
  • Explaining automation logic
It functions as an intelligent partner for developers, testers, and analysts — not replacing them, but amplifying their capability.
1.3 Context Grounding (Cg) — Aligning AI Reasoning to Enterprise Reality
LLMs generate outputs based on statistical patterns.
Agentic AI requires outputs based on business truth.
Context Grounding bridges this gap by:
  • Injecting enterprise data into prompts
  • Standardizing what information each agent receives
  • Reducing hallucination through structured grounding
  • Ensuring decisions align with systems-of-record
Grounding transforms an LLM from a general model to a domain-aware reasoning engine.
1.4 AI Trust Layer (Tl) — Governance, Safety, and Responsible AI
Enterprise AI must be:
  • auditable
  • secure
  • compliant
  • respectful of privacy
  • free from unsafe outputs
UiPath’s AI Trust Layer enforces:
  • redaction
  • safety checks
  • toxicity filtering
  • role-based access
  • parameter control
  • secure model invocation
  • content filtering
  • traceability
It enables innovation without introducing risk.
1.5 Elastic Robot Orchestration (Er) — Intelligent Scalability
Agentic workloads are variable and unpredictable.
Elastic Robot Orchestration manages this by:
  • Scaling robots and agents up or down automatically
  • Optimizing resource usage based on real-time demand
  • Reducing infrastructure cost
  • Handling burst workloads or peak hours
This makes agentic systems production-ready, not proof-of-concept experiments.
1.6 Memory & Context Architecture (Lm, Sm, Mc) — Enabling Learning and Adaptation
Modern enterprise agents need to do more than respond; they need to remember.
The core memory layers are:
Short-Term Memory (Sm)
Session-specific information — useful for multi-turn interactions.
Long-Term Memory (Lm)
Knowledge that persists across sessions and tasks.
Model Context Protocol (Mc)
Standardized context exchange that allows:
  • multiple agents to collaborate
  • state to be shared across tasks
  • downstream reasoning to remain consistent
This enables agents to behave more like knowledgeable coworkers.
2. Why These Elements Matter
Together, these concepts enable automation that is:
  • Context-aware
  • Self-improving
  • Collaborative
  • Grounded to enterprise systems
  • Governed with safety and transparency
  • Able to reason and plan, not just execute
Agentic AI is not simply about using models.
It is about designing systems with autonomy and accountability — where humans, robots, and AI collaborate under clear guardrails.
This framework helps teams:
  • understand the components of an agentic system
  • map capabilities to use cases
  • communicate with architects and business stakeholders
  • design predictable, trustworthy, enterprise-safe agents
3. About the Agentic AI Periodic Table
The periodic table is an illustrative concept created to help simplify and explain the evolving landscape of agentic capabilities.
It includes:
  • AI terminology
  • UiPath platform tools
  • Multi-agent coordination patterns
  • Memory and context-handling concepts
  • Deployment and scalability mechanisms
  • Enterprise governance and safety components
  • Business and operational use cases
  • Evaluation and optimization methods
It is meant for education, conceptual alignment, and community learning.
Created by
Logesh Velu, UiPath Community MVP 2026
Please reach out if you need anything or have questions.
