I have two machines A and B, on machine A I have orchestrator and on machine B I want to run one process which has UI automation but I want to make my screen B locked and wants to check execution of process from machine A. How I can do this?
Install the bot in service mode and then try running…
Idealy that should work.
Publish your process to the orchestartor.
You should have an unattended license in your orchestrator and that license should be assigned to the machine B
You can check the logs you used in the process in the logs panel of your process.
Install the studio in the Machine B in service mode as mentioned by @Anil_G
Regards
Sudharsan
