Type conversion exception problem
Phase1 Industry Project Weekly Stock Price.zip (111.3 KB)
Hi, When I first run this project it worked perfectly fine. But now it is giving me type conversion problem for average close price and volume. Please help me with this asap.
Hello @Priyanka_Jharia
Could you please share the full error which you are getting and in which activity you are facing this issue.
In this following activity I think because of the expression.
and I use this expression
ReadTstWkb3.AsEnumerable().Average(Function(row) cDbl(row(“Close”).ToString.Trim))
@Priyanka_Jharia ,
Try changing the Expression to the Below and Check :
ReadTstWkb3.AsEnumerable().Average(Function(row) if(String.IsNullOrWhiteSpace(row("Close").ToString.Trim),0,cDbl(row("Close").ToString.Trim)))
Didn’t Work. Giving the same exception.
@Priyanka_Jharia ,
Are you using the above Expression directly in the Write Cell Activity and Checking it ?
If so, Could you just use the Expression in a Message Box before using in the Write Cell Activity to Check if it gives out an Error in it as well ?
Also Share the Screenshot of the Expression used in the Message Box.
Hey, It didn’t gave error in Message Box as you can see and I used the same expression that you gave me in the message box but I have to write it in excel sheet in which it is creating error still. Please let me know how can I do this.
@Priyanka_Jharia ,
Does it give out the Same Error or a Different Error ?
same error
@Priyanka_Jharia ,
In that case, Could you try Assigning that Expression to a Double Type variable and then use that variable in the Write Cell Activity ?
same error I faced…
Hey I resolved it by myself thankyou for your input.
Did you have the same problem like me that it first worked great then it created error?
