These Columns only Update
Other Columns and its Values remain Same…
Thanks
Shyam
Check the Updated Workflow Below which follows a Linq Approach :
DT_ConditionUpdate_Rows.zip (3.6 KB)
Also, there is a commented activity part which uses the For Each Row
method. You could Check which will work better for your Large Data and use it accordingly.
Thanks You
I need one more Correction.
Target Hrs colunms convert to time format “07:00:00”
Do You have Any Study Material for Linq Uipath (Special for Uipath)?
Thanks
Shyam
Check the Updated workflow below :
DT_ConditionUpdate_Rows.zip (3.8 KB)
For More On Linq, Check Below :
Performing hands on work on these Categories would help you to explore more about Linq, It’s uses, When to use and when it can be helpful.
