@"[\s]{3,}", “|”
here i have error
Which language do you use, VB or C#? if you use VB, can you try to remove remove “@”, as the following?
VB
System.Text.RegularExpressions.Regex.Replace(new_String.Substring(var_Start_Index, var_End_Index - var_Start_Index), "[\s]{3,}", "|")
C#
System.Text.RegularExpressions.Regex.Replace(new_String.Substring(var_Start_Index, var_End_Index - var_Start_Index), @"[\s]{3,}", "|")
if you have still error, can you share the error message.
still error
Error ERROR Validation Error Compiler error(s) encountered processing expression “System.Text.RegularExpressions.Regex.Replace(new_String.Substring(var_Start_Index, var_End_Index - var_Start_Index), “[\s]{3,}”, “|”)”.
Expression expected. Main.xaml
it is solved
thank you
also i found this error i remove @ but still
Error ERROR Validation Error Compiler error(s) encountered processing expression “System.Text.RegularExpressions.Regex.Replace(new_String.Replace(”\n", “"), “\s{2,}”, “|”).Replace("”, “\n”).Split(’\n’)".
Can you try the following expression?
String.Split method can have only char type or its array for argument.
If you want to split it by chr(10) : LF, the following works.
System.Text.RegularExpressions.Regex.Replace(new_String.Replace("\n", ""), "\s{2,}", "|").Replace("", "\n").Split(vbLf.ToCharArray)
If you want to split it by “\n”, the following will work.
Strings.Split(System.Text.RegularExpressions.Regex.Replace(new_String.Replace("\n", ""), "\s{2,}", "|").Replace("", "\n"),"\n")
it solved but until now i can not understand the error
when i use regex this error is append
Error ERROR Validation Error Compiler error(s) encountered processing expression “hader_Line + String.Join(”\n", arrey_String.Where(Line => System.Text.RegularExpressions.Regex.IsMatch(Line,"^\d{2,}")))".
‘.’ expected. Main.xaml
also that sorry
Your expression seems C#. Can you try to use VB expression as the following.
hader_Line + String.Join("\n", arrey_String.Where(Function(Line) System.Text.RegularExpressions.Regex.IsMatch(Line,"^\d{2,}")))
If you want to Join linebreak, the following might be better.
hader_Line + String.Join(vbLF, arrey_String.Where(Function(Line) System.Text.RegularExpressions.Regex.IsMatch(Line,"^\d{2,}")))
Or we can choose language (VB or C#) when create project. If you are familiar with C#, it might be better to re-create your project as C# mode.
ok and thank you
