System.InvalidOperationException: Error initializing Python engine ---> System.InvalidOperationException: Python deserialization exception ---> System.ArgumentNullException: Value cannot be null. (Parameter 's')
Using UiPath 2024 version with windows and python version is 3.9 while running the python code getting below error in python scope
System.InvalidOperationException: Error initializing Python engine —> System.InvalidOperationException: Python deserialization exception —> System.ArgumentNullException: Value cannot be null. (Parameter ‘s’) at
@Manaswini_UI,
Can you share how you are configuring the Python Scope?
Hi @Manaswini_UI
Could you please:
  1. Share a sample workflow where you are encountering this issue
  2. Run the following two commands in the CMD and share their output:
    dotnet --list-runtimes
    dotnet --list-sdks
  3. Details about your Python installation → is it coming from the Python installer or from the Windows store?
It would help us debug the issue a bit better.
