I have given delay of 3 seconds.
Yeah @Vidya_Srinivasan
That is just to avoid erroring out if there are no background processes running in task manager.
Are you still getting the issue with the selectors?
No i didnt…this error came up after 3-4 successful transactions.
So all applications closed.But i didnt see the selector issue so far.
Please try running it again and let me know the results
I wish better luck next time.
I was able to process 12 out of 14 transactions.
And then the same error.
Do u think i should increase the delay timing from 3 seconds to 6 seconds may be ?
Yeah. I hope the files are still opened in the back end.
Can you please let me know why you are trying to open the same excel again and again @Vidya_Srinivasan
And you are trying to open it from the temp storage?
I am not trying to open same excel again and again as per my understanding if i am not wrong.
The steps are as follows :
1)I tried to check if the file has been created using while loop.
2)We then use kill process and delay to avoid overlap between creation and reading.
3)Then i read the fille (CSV)
All my monthly reports and yearly are stored in Temp folder.Are they expected to be different.System1_CreateYearlyReport.xaml (31.9 KB)
Attaching the XAML file.Please let me know if i am missing out on something.
You are using the Kill process in catch activity @Vidya_Srinivasan,
please move it to try and then give a check
Thanks a lot for helping me in my last crucial doubts.
I cleared assignment 2
